trans grinding
Sdavne
Car: Nissan 300zx n/a 2+0 5 speed sliver
90 na when im racing and in first and I shift into second don't times it grinds a little. I have an act 2 stage with a never duty pressure plate with less than 10 k on it is this normal or is somthing not right. Thank u Scott [email protected]
bbecker17
Car: 1991 240sx.... dead
1990 300zx tt jdm
bad synchro's in the transmission. you can try some better transmission oil but thats just a quick fix
Sdavne
ok i will give that a try, is there a drain plug on a manuel for the trans fluid cause i might just replace allthe trans fluid.also can i drain the rear of is it a closed system?
bbecker17
1990 300zx tt jdm
there are drains for the differentail and the transmission,
the transmission drain is right on the bottom of the transmission it should be a plug with a 1/2 inch square
the transmission fill is on the right side of the transmission half way up looks the same as the drain.
always make sure you can get the fill plug out first before u take out the drain plug.
you should be able to find the two on the rearend they look the same as the transmissions
