Trans Fluid
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
2kredz3
Car: 1984 Nissan 720
i have found that it is recommend to use GL4 in the trans and the transfercase. what do you guys use? i found amsoil carries a GL4 replacement but after installing it i have some whine. input would be great
PEZi
i absolutely love amsoil in the engine... but my transmission has royal purple 75w 90 and it works fine
i'm thinking of changing it to a mix of 15w 50 and royal purple synchromax soon though and i'll let you know what happens
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
I used whatever GL-4 they had there. My only suggestion is the order of fluid change.
Remove filler bolt(if this doesn't come out it makes it hard to get fluid back in)Remove drain boltDrain fluidReplace drain plugUse oil filler, oil pump, or equivalent (i didn't do this and had to fill through a tube running through the shift in the cab)then when the oil starts pouring back out of the filler plug, replace the filler bolt
Mine makes a noise but I think its my throwout bearing or clutch. kinda sounds like a spring unwinding.
2kredz3
PEZi303 wrote:i absolutely love amsoil in the engine... but my transmission has royal purple 75w 90 and it works fine
the amsoil i put in is the 75w80 synchromesh fluid (i am an amsoil dealer so i had to try it)
i can tell you the RP synchromax is too thin as it is more like a 5w20 or a ATF fluid.
Return to “Datsun 720”
