Here's a picture below from my first ATF fluid change where the pan was removed to change the screen, gasket, bolts, and to clean the magnet.
Since I was removing the pan inside my garage, I wanted to extract as much fluid as possible to avoid spilling any fluid on the floor. I used the Pela pump for the initial fluid extraction. I knew once I tapped the bottom of the pan with the extraction tube that I might be able to extract more ATF than the amount that would be drained by just removing the drain plug.
In the picture below, the area in (a) shows marks on the pan bottom where the extractor tube landed. The area in (b) shows the drain plug riser and thread collar. I really don't remember any mess associated with removing the pan in the garage that October night. The picture shows how a minimal amount of fluid would have been left in the pan bottom.
While the pump can only remove the amount of ATF that is present in the pan, the idea for the extractor pump is an easy method for a DIY type person to change engine fluids on a routine basis.
I do not recommend the pump for changing VH45DE engine oil as it cannot hit the bottom of the oil pan like it does the ATF pan.
