trans fliud recomendation 02 q45?
xerexabante
Car: '02 Infiniti Q45
'02 Nissan Maxima SE
anyone can recomend trans fluid for 02 q45? i just got this 1mo. ago. love the car!
Use the dealer-recommended Nissanmatic fluid. I cant remember if it was Nissanmatic J, Nissanmatic D, or something else.
EDIT: It is type J!!!
Modified by Jesda at 9:54 AM 9/30/2006
xerexabante
thank you.
Q45tech
The newer 5AT uses a different viscosity and stick/slip ATF to better prolong the life of the new 2 stage lockup clutch. Dexron 111a-g are not compatable.
xerexabante
found castrol synthetic that says it is compatible, is it tru or should i buy from dealer.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Buy from Joe if he can ship. Use of any other fluid will invalidate your warranty.
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
1. you have nissan type J fluid in your re5r05a transmission.
2. castrol does make a type J fluid. didn't know it was synthetic. i sold my g35 with same trans after only 1 drain and fill with genine nissan j fluid. at the time i couldnot locally source the castrol j.
Modified by GQ Jay at 8:05 AM 9/30/2006
