trans. ecu, tcu calibration
levsal
Car: 1995 infiniti q45
I installed a used trans. on my 95 q45. I was wondering if there is a tcu or ecu calibration that needs to be or can be done. a friend i bought the car from said it didn't take much throttle to power brake the car and spin the tires.Now after installing this trans, I have a hard time doing this.
qship96
Car: 1996 Infiniti Q45
If that is how you friend treated the car, you should not have bought it.
Certainly explains why you needed to replace the transmission.
KIDS and Q45`s are a bad combination
levsal
it's not something that was done everyday. it's my car now and i've done it or at least tried.
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
What year is the car the transmission came from?
superuber
Your first problem is "used"! Maybe the trans you put in is junk.need more info.
Q45tech
TCU software is designed to function on a new to in warranty transmission.
Really only tells transmission when to shift/downshift................the performance of transmission is set by transmission internals.......mechanicals
superuber
If you wanted to spin the tires should have put in high stall tc!kids and Q45 don't mix! Oh wait, someone said that!!!!!!!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Or get really billiard ball hard rear tires.
Welcome to high school dropouts.
