One of the previous owners had the trans replaced about 30k ago along with an external transmission cooler installed. I've been noticing trans fluid where I normally park the car so last time I drove it to work I pulled it in the shop and took a look at it. Not sure if the trans lines were all tube, or tube / rubber originally but now each line has about a foot of rubber trans line between 8" and 12" off the trans. So I'm leaking fluid from all four points, both ends of each rubber hose where its hose clamped onto the tubing. Looks like it was cut and poorly attempted to flare the ends, instead of beading them. I was going to see if a shop could bead them, but then I thought, why not put better lines on almost all the way up to the ext trans cooler. Anyone know the size/pitch/type of connection these lines have at the transmission ? I can't find it in the FSM. Also where might I be able to find/buy the lines ?
Thanks in advance
~Dave~
