qship96 »
https://forums.nicoclub.com/qship96-u3104.html
Thu Feb 26, 2009 11:23 am
I dont have a diagram of the external filter- and I dont think it is even mentioned in the factory service manual- very, very easy to change, just R&R the 3 hoses- once you look at the kit, it will be self explanatory.
The internal pan mounted screen is best left to a shop with a lift, and it is a messy, dirty job as ATF drips for hours once pan is off.
I would do both filters if neither has ever been done, but the external one is the more important of the two,as it is prone to load up quicker due to its fine particle filtering ability, whereas the internal screen will let all but the largest particles pass right through it, and transmission would have to grenade itself to clog the screen.
