sijoko »
https://forums.nicoclub.com/sijoko-u297.html
Tue Apr 29, 2003 8:50 pm
Stephen,
The procedure to change the trans. is not that complicated. I did it in my garage using an air impact wrench, transmission jack (from Harbor Freight) and a really good breaker bar for the bellhousing bolts (some of them were so tight, that the air impact wrench could not budge them).
The factory service manual shows you everything. Two mechanically inclined people can knock it out in a weekend.
I am not saying that it is a piece of cake, but that it is do-able. If you had access to a lift, it would be much easier.
Hope this helps.
