<transmission>won't go into gear, help!!
DrifterXRPS13
Car: 1993 Acura Integra LS, 1998 Nissan 240SX SE 5sp. KA-T,2004 Honda CBR 600RR, 2005 Suzuki GSX-R 600, 2013 Harley Davidson Iron 883, 2014 BMW S1000RR
hey fellow nicoers, i have an 89 240 with ka-e motor and trans. it's completely stock, it has 150,xxx miles on it and is in fairly good condition. I've had the car since september and i know it has a few problems like when it's in first gear it makes a weird bird chirping sound, it also feels like wheel hop when it's in first gear, mostly in the lower rpm's. My question is lately 1st and 2nd gear have not been going in gear. When i do finally get them in, it takes all of my strength to get it in there. When the cars in neutral and you try to put it into 1st gear you can hear a loud thud, it won't go into gear but you hear the thud, it's even louder when you try to put it into 2nd. It's been doing it a lot lately. Could it be that the trans shifted somehow or is it my clutch, i checked the transmission fluid and it's fine,i don't know what it could be but any help from anyone would be appreciated greatly.
Thank You.
DrifterXRPS13
Come on guys a little help, anyone? Is there anyone out there that could even mention something about this problem that i'm having. any help would be great. thank you
Silvia007
Car: 93 Nissan 240SX SE Fastback
You mention a clutch so I'm assuming it's a 5-speed manual. First off, checking the fluid on manuals is a pain in the a$$. If it's full, do you know if it's GL-4 or GL-5? You can usually tell by the smell but if you're not used to the way they smell you can't tell. If it's GL-5 and you got to that point then well, new transmission because GL-5 has an addictive that disolves brass (which is used for our syncro's). I'd change the fluid anyway just for the hell of it.
jmartinz32
Car: CARS, MUSIC
Drifter- Ive searched the archives and cant find help on a problem similar to yours - my car will not go into any gear while sitting idle. when car is off it goes in fine to all gears. if i can get a rolling start it shifts o.k., even downshifting. any advice would be appreciated. thanks
240dreams
Car: 240's
jmartinz32-i think that is a problem with ur master or slave cylinder. http://www.store.yahoo.com/pha....html
Importroller
Car: G35 and 07 Altima 3.5 6spd
u figure out the problem yet
jmartinz32
Car: CARS, MUSIC
Not yet. heading there today. the car is not at my home. i have put new slave cylinder on, but after reading approx. 570 posts i fell it just needs a good bleedin'. my wife will do the pumpin'. i'll be looking for air. (we are a close couple). i'll let you know what happens. thanks for all the help NICO.
Ender_Zero
Car: '03 Base Z, '91 S13 Coupe
if it feels like wheel hop when starting off, and you arent breaking the tires loose, its clutch chatter. usually a good sign of a clutch going out.
