transmission whine and clutch failure diagnoses needed quick
centralcoaster33
Car: 1997 Nissan 240SX #5
Hey, I need assistance in diagnoses of my issue to save $$ by not buying stuff I don't need. I have a 97 240sx manual. I put a new exedy clutch kit and fidanza flywheel in about 1 year ago. I drove it a lot since. About 5 months ago, my transmission started to whine (people thought I had a crappy turbo in there, I wish). It would whine louder and higher pitch at higher RPMs. It would whine in every gear except fourth. It didn't really whine in neutral. A couple weeks ago, I was on the freeway in 5th. I didn't hear any weird noises, pops, cracks or anything as I drove. I exited to an off ramp and threw it in neutral and coasted to the stop sign. When I wanted to go again, I pushed in the clutch and couldn't shift back into first. I can't shift into any gear while the engine is running and I'm not rolling. I can see the slave cylinder moving with my pedal, so hydrolics are okay. I moved the rubber boot aside and could even see the splines from the pressure plate move a bit with clutch pedal depression. If the engine is not running, I can shift into any gears and the clutch pedal pressure feels normal. If the engine is running, I can't put it into any gear (pressure plate doesn't seem to let go of clutch) and the pedal feels a little weird at full depression. I hope the transmission whine and clutch failure are both related to a cheapo Daiken brand throwout bearing and maybe that's all I need to buy. Will transmission need rebuild to fix the whine (maybe carrier shaft bearings)? Will I need a whole new clutch kit. Any experienced advice please and soon? Thanks. PS, I was able to get the car home by putting it in 1st with engine off, using the starter to get the car rolling and then rev matching through the gears all the way home. All gears still worked, just no clutch to assist in shifting.
centralcoaster33
Lunch bump. Need to order parts. Need to know if parts are clutch kit, transmission rebuild kit, or simply throw-out bearing and bush.
jdm_master_X
Car: 92 Nissan 180SX LHD!...LaWL
you have a bearing problem with your input shaft.
centralcoaster33
Hmmm, thank you for the reply. I've been on the edge of my seat all morning waiting. Is that in reference to the whine? Could that bearing be bypassed by fourth gear? I ask 'cause no whine in fourth. There's no relation between that bearing and my clutch not working is there? Finally, I've seen rebuild kits with like six ball bearings, one needle bearing, a couple of nuts and a few screws. But my transmission pictures something like 10 needle bearings. Should I not care about replacing needle bearings, springs, inserts and baulk rings when rebuilding a transmission?
centralcoaster33
Heading out for the weekend soon. Nows your chance to flaunt your wisdom!
