tad_240 »
https://forums.nicoclub.com/tad-240-u3509.html
Wed Nov 13, 2002 12:43 pm
i have a funny noise coming from the transmission and my mechanic told me that it was the throw out bearing. he also told me that the shaft that it rides on can get worn after time, i own a 90 240, and even a new throwout bearing can make noises riding on a bad shaft, and it will sound the same too. my car makes the noise when it is cold, and just like said above, it usually goes away after a couple minutes and a couple shifts, but it is winter here now, and during really cold days, it will continue to do it far a long time after it would normally go away. when the car is sitting running you can hear it shimmy and sound like it is vibrating, and when you press in the clutch a little, it goes away, but when shifting when it is cold, especially in reverse, it starts to squeal right when you almost have it let out all the way, or when you shift at higher rpms when it is cold. if this helps any then cool, or if any one has a suggestion for me, then good too. thanks
:smoker
