Skibane »
https://forums.nicoclub.com/skibane-u40096.html
Tue Jun 26, 2007 5:57 pm
Although they're harder to install, the mechanical transmission temp gauges (like Auto Meter makes, for example) are more accurate. Most of the electrical ones have just a few temperature markings on the dial, and the needle only swings over a small angle from lowest to highest temp. By contrast, some of the mechanical gauges swing 270 degrees or so, with enough markings to read the temp down to a few degrees F.
