RBpoweredSileighty »
https://forums.nicoclub.com/rbpoweredsileighty-u22478.html
Thu Dec 09, 2004 12:04 pm
not sure if you wanted to do this or know how to weld but, you could drain the fluid, pull the transmission pan off, clean the inside of the pan, find a mount that will work, cut the hole out and install the mount by welding it up fully, install the sensor, wire it up to the gauge and there you go. btw make sure you will have clearence for anything that is inside or outside of where you want to install the sensor.
good luck!
