to pull both? easy. it depends how your doing it, just on jack stands? i did mine over a pit and it was a piece of cakeleveledlife wrote:exactly how hard is it?
Yeah i dont understand...Its going to be EASIER (much) to bolt the trans to the engine in your driveway than it will be in the cramped engine bay. So you attach the trans to the engine, then drop them in together.darens13 wrote:how else would it go on? the trick is to bolt it together.
Seriously? Ok, ready? Here ya go:1) Get everything off of the transmission.2) Remove transmission crossmember.3) Unbolt engine from mounts.4) Pull both out together.5) Done.leveledlife wrote:well why dont you tell me how to do it smart a** im not incapable of doing that thats what a FORUM is for.. thankyou!!
