transmission?
240sxGT
Car: 97 Nissan 240SX SE
98 Nissan Maxima SE
93 Subaru Imprezza
Yes I searched, Is there any 6 speed traany that will bolt directly onto a KA24DE? If not how much work will be involved to get one to fit?
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
I really don't think anything will be a direct bolt on for that. I would look into either a Max SE 6spd or the SpecV 6spd. Those really are your only 2 choices here. But since you drive a 240(guessing here) I don't thik there are any choices without considerable machine shop work. The only RWD 6spd Nissan offers is for the 350z.
Sidewayz
Car: Driving, tuning my car and working
first off why in the hell would you need to get a 6spd for a 4 cylinder motor, unless your going RB powered or some other 8 or 6 cyinders. Our 240's are not made to do 155 mph, and if you are going to be going that fast you can just change the gear ratio and make them longer, but then by doing that your quarter mile will be affected and your car will make power more into higer rpms making it a topspeed vehicle. Id say if your looking for a 6 spd look into the skyline transmission out of the r32 maybe with alot of farbrication of the bell housing and wireing harness and transmission mounts you might get away with it, but only your skill will allow you to accomplish this task. Also the transmission out of a 300zx might work with also alot of fabricating its a 5spd but with its ratio will almost perform like a 6spd unless again if your going for topspeed, 300zx's are designed to do 155
Rev_D21
lol I was trying to avoid saying the word Skyline.
Everything works with the right amount of $$$$$$$$.
deviousKA
Car: 90 240sx NA /72 Datsun 510 NA /86 corolla GTS NA
s15 transmission is 6speed, to much to make one work with a ka, and i hear they are not as strong as the 5speed
Sil240
Car: Nissan S13 "The One Cam Wonder"
umm i dont know if this is true but i heard all the ca/ka/sr/rb gear boxes were very similar and that just the bellhousing were diff and of course the gears
