transmission
smellslikecurry
quick question i tried finding this but i cudnt - will a 89-90 manual transmission fit into a 97 s14 for a transmission swap
daniel240
Car: cars/motocross
i wouldn't think so, but im not sure on that one. why would you want that old of a transmission in your 97 anyway?
quiksilvia
Car: 95 s14 se
thats a good point dannynoy, but i think the bell housings are different
LTSCUDRFT
i thought the engines were identical other than the heads :confused:
574-240sx
Car: Nissans, Toyotas, Subaru
Well the 89-90 transmission worked in my 92. I don't know about obd-2 and the different sensors. Flywheel size and etc. In my car all I had connected was speed sensor. With you car being newer it will probably throw sensor codes resulting in the check engine light. Nick
smellslikecurry
the 90 transmission is fairly new and i got it off a friend who i knew drives well
knowleqe
it will fit, but the sensors wont match up because s14 is obdII
240doc
mechanically it will bolt on. I just bolted a 97ka24de to a 1989 manual trans. which is in my car. as far as the sensors go, see if they are similar to the ones on the older trans. in other words you might be able to switch out the sensors to yours so the harness will still plug in to them. hope this helps
mattlord42
Car: 1991 240SX Coupe
I believe that you could also just use the guts from the 90 transmission in the 97 bellhousing if you needed to but I don't know if that would effect the sensors at all.
Matt
smellslikecurry
thanks - should i try and swap it??
LTSCUDRFT
check the sensors see if it'll work. hope it works out for ya, :thumbup
smellslikecurry
240doc do u have any problems with ur transmission?
240doc
sorry for the late reply, no I don't have any problems whatsoever with my transmission. everything bolted up great, and now it shifts and runs great.
BTW, it is an 89 transmission mated to a 97 KA24DE engine.
knowleqe
what did you do about the sensors?
240doc
well in my case the sensors were the same. I have a wire harness from a 91 car installed into the body of an 89. so this means that the sensors on the transmission from 89-93 probably connect the same way. Now for the S14 harness to connect to the S13 transmission sensors, that might be a different story. but I believe the 5-spd trans is the same for all. So, you could probably install an older transmission into a newer car, mechanically they are the same, just pull the sensors from your old (s14) transmission and install them into the used (s13) transmission. That would solve the connectivity issue.
