transmission
Red93coupe
Car: 1993 CA powered Coupe-sold 1996 Maxima 5spd all black, 1992 300zx all black 2+2 soon to be TT
Alright well here is a dumb question, I need to put some more gear oil into the transmission, well before the install I removed the big plug that is directly on the bottom of the transmission, well the guy that was helping me tipped the transmission up and about a Quart drained out, So now that its installed how do I put more in now thats everything is installed???
boost_boy
Red93coupe wrote:Alright well here is a dumb question, I need to put some more gear oil into the transmission, well before the install I removed the big plug that is directly on the bottom of the transmission, well the guy that was helping me tipped the transmission up and about a Quart drained out, So now that its installed how do I put more in now thats everything is installed???
Remove your shifter and dump it in there!
Dee
Red93coupe
boost_boy wrote:Remove your shifter and dump it in there!
Dee
So remove the six bolts and dump some in there???
Masterdebater
Car: 1989 nissan 240sx coupe
just pull all the plastic center consol around the shifter off, pull the c-clip holding in the shifter and fill 'er up!!
Red93coupe
Masterdebater wrote:just pull all the plastic center consol around the shifter off, pull the c-clip holding in the shifter and fill 'er up!!
Ok thats easy thanks!!!
Red93coupe
Well I couldnt quite ge it I only have a few tools because im at school, but i have the tools to pull the 6 bolts out can I do that instead!!
jt15833
Car: 95' 240SX
its a pain in the *** you probably need to go under the car for the up front ones. you could buy one of those pumps you put on top of the gear oil quarts and use the fill hole.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Uuuuh, does no one use the proper method for this? You know there is a fill point on the side of the transmission right? Use a 1/2in drive extension and put it in the square plug up on the pass. side of the transmission. Remove it and fill with 75w90 until it is level with the hole (its like a liter or two, cant remember). I believe this is how the FSM says to do it. Nice because you cant over-fill it this way. Dumping it down the shifter hole just sounds so sketchy.
Red93coupe
r34 gtr wrote:Uuuuh, does no one use the proper method for this? You know there is a fill point on the side of the transmission right? Use a 1/2in drive extension and put it in the square plug up on the pass. side of the transmission. Remove it and fill with 75w90 until it is level with the hole (its like a liter or two, cant remember). I believe this is how the FSM says to do it. Nice because you cant over-fill it this way. Dumping it down the shifter hole just sounds so sketchy.
Well the problem is that I'm at school its hard to get underneath my car and i have no access to a jack so dumping it down there is easiest
boost_boy
r34 gtr wrote:Uuuuh, does no one use the proper method for this?.
If there is a simpler way that produces the same result less the extra dramas, why would you follow what is considered the correct way? Factory boost settings are supposed to be between 5 and 7 psi of boost, but there's not many of us that care to follow the factory's recommendations and still get excellent results (welcome to the world of performance development).
r34 gtr wrote:Dumping it down the shifter hole just sounds so sketchy.
You're entitled to your opinion, but it works and it takes alot less effort than jacking-up a car, getting under it and possibly putting yourself at risk of getting hurt when there is a way that helps you accomplish the same goal. Hell, some of you may aswell use the factory boost solenoid if you want to go the proper route . But again, you all can feel free to do whatever you want the way you want to your car because it is yours as well as any of your opinions.
P.S. I actually use the proper method for my FWD configuration because any other way (and there is more ways) would complicate such a simple task .
Dee
r34 gtr
I dont know, I tend to use coastal gear oil (you know, the really, REALLY cheap stuff) and it comes in those 1l bottles with the length of hose on the end. It actually seems like much less work than removing the shifter because I dont actually have to crawl under the car to do it. If you didnt have the hose thing (god forbid) it would totally suck. 1 large cap screw = less work than however many bolts there are in the mystery that is my shifter plate deal.
boost_boy
I'm still trying to see where I said for him to remove the shifter plate . I personally would never remove the plate itself and I wouldn't recommend it to anyone as it is just too much work. When I told him to remove the shifter, I meant just the shifter and not the plate and if this clears things up for everyone, then there you have it. Just need to remove the circlip that hold the actual shifter to it's base and pour 3.2 quarts of gear oil in that puppy and call it a day.
Dee
r34 gtr
Ah, sorry, my mistake. I thought you were talking about surgery to the top of the transmission. My circlip is worn out like a 75 year old prostitute, so I try and avoid it at all costs, but whatever works easiest I guess.
boost_boy
r34 gtr wrote:Ah, sorry, my mistake. I thought you were talking about surgery to the top of the transmission. My circlip is worn out like a 75 year old prostitute, so I try and avoid it at all costs, but whatever works easiest I guess.
A 75 y/o prostitute has some beat twiz-at, but I'm sure you'd hit for a case of brew or a bottle of Jack .
Dee
