transmission swap wiring ?
sycle
Car: 1989 240sx
Ok, I have looked and read through a lot of the different posts on the wiring for the 240sx auto to manual swap. I keep on getting the same information. That it is the top connector behind the battery and fuse box. Everyone says that it is a double female connection. My car is a 1991 nissan 240sx coupe se. I have the three relays right their with a fourth under the fuse box. The top relay has three female connectors and has a black, red and white wire coming out of it. I do not know which wire i am supposed to crossover. It would be greatly appreciated if anyone could give me any help.
tonynalli
i believe that i jumpered the neutral safety switch by using the bottom connetor, i wish my teacher would let me outta school right now, but i belive that it was the bottom plug.
sycle
Car: 1989 240sx
See that is where my problem is. I jumpered the wires right below the fuse box. They were black and like a light tan. I however still wont start. It gives me a clicking sound, friend told me that was from car thinking it is still not in park. So i dont know where to go.
SHIFTrl240
Car: 1990 SR20 Sil-80
2009 Yamaha RoadStar Warrior
2017 Alfa Romeo Giulia Ti AWD
battery dead? happened to me when i did my swap, didnt have anything on either.. just happened somehow
what i did was cut the connector off of the auto harness, and used the wires from that and jumpered it
the plug you want is the one that is hanging, not mounted on anything.
sycle
Car: 1989 240sx
yea i got the one that was hanging right below the box. It cannot be the battery because i get all the beeping when i place the key in with the door open. So i have all the power, i just have the clicking from the ignition switch.
