transmission swap
C4ORCE
Car: 1990 2+2 with JDM TT swap
hey guys need a little info i have a 90 twin turbo with an automatic :frown: BUT my wife has a 90 NA with a 5 speed. well long story short she wants my trans and i want hers but i know that my car has a tcu under the floor board beside the ecu and im pretty sure hers doesnt (cant check as the car is not at home). my question is would i have to swap the wiring harnesses out in both cars to make this work? also would i need a new ecu or would the one i have now work? thanks in advance
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
To make the Auto a 5 speed, no harness swap, but you WOULD have to if you want to make the 5 speed Auto.
C4ORCE
yea thats what i thought just wanted to be sure
NolimitZ32
Solution:
Give her your TT (she will be very happy)
Sell her NA and put towards a slightly faster Manual TT for you (you will be happy
Now you are both happy :D
Rager
Car: 1992 Nissan 300ZX 2+2
1999 Nissan Sentra
2004 Chevy Silverado
A^ and they could get plates saying "hisz" and "herz" :chuckle:
300ZXttZMAN
Great ideas^ everyone would be happy plus you wouldn't have to do any labor.
C4ORCE
well guys theirs a flaw in the slaw lol my car is finished other than a few little quirks that should get taken care of this weekend and her car is in a million pieces being built to show at NOPI
and would the ecu i have work with the 5speed?
bartZ32tt
Car: 1990 300zx twin turbo, 1996 7.3 powerstroke
auto-5spd: yes, you can retain auto ecu. Not the case for manual-auto swap.
DankZX
Car: 1991 N/A 300ZX: Few Mods
1996 Sentra GXE
Will the N/A transmission hold up to the TT's power? I know the manual TT's have stronger internals and so on. I know the gear ration would be in favor of this but if the thing breaks thats alot of work for nothing.
Ace2cool
They did drop the power for the A/T, now that you mention it.
EDIT: It'd be an auto TT trans being mated to the N/A engine. We all know the M/T can hold its own. It would be fine.
C4ORCE
yea it would be a TT auto going to a na motor so it would be fine and from my understanding the 5 speeds were the same for na and tt models so should be no issue there i'll just need a stronger clutch set up.
Z-owned
Car: 93 N/A Z32
90 VW Corrado
01 mr2 spyder
The tt uses a larger sized flywheel and pressure plate which requires the n/a transmission's bell housing to be grinded a little to fit it. will need the starter spacer as well.
C4ORCE
thanks z-owned i wasnt aware of that but ill keep it in mind
Z-owned
Car: 93 N/A Z32
90 VW Corrado
01 mr2 spyder
NP here is the starter spacer (shim) whatever you prefer to call it lol as far as having to shave the bell housing it's really not that bad as there isn't much needing removed.
http://www.conceptzperformance.com/Cart ... .18.11.140
Fearspect
Car: 1990 Nissan 300zx TT 2+2
DankZX wrote:Will the N/A transmission hold up to the TT's power? I know the manual TT's have stronger internals and so on. I know the gear ration would be in favor of this but if the thing breaks thats alot of work for nothing.
I thought that, other than the flywheel and bellhousing size, the two manual transmissions were otherwise the same. There is a difference in the VLSD though.
C4ORCE
ok guys thanks for all your info i'll order that shim in the next few days
