transmission swap question
prefontaine240
ok here what's up with my car, it's a 92, the guy I bought it from tried to swap in an sohc engine and ecu, he couldn't get it to work so he sold it, I think he just wired the ecu wrong (if you know anything else that it could be I'd appreciate that too), but what I need to know is will the 92 transmission work with the sohc, and do does it matter whether the ecu came out of a auto or standard, the car is currently auto but the guy didn't tell me if he got the sohc ecu out of auto or standard so I wasn't sure if that could be the problem.
Any info on this would be greatly appreciated!
Thanks,Mike
slw240sx
Car: 1990 Ca18det 240sx Hatch
im pretty sure an auto needs the auto ecu for ignition reasons an park lock stuff i know you can runa 5speed off a auto ecu but you would encounter problemns i think all 240sx trannys work with all years 89-97 i believe
drjohn
The only thing I can tell you is to get a ecu wiring diagram from both cars and try to rewire the ecu connector.
