transmission swap question
djb5118
i have access to an s14 transmission and was wondering if I get an s13 auto, would I be able to put the s14 5spd in the s13?
would it be a straightforward swap or no?
djb5118
I posted this in the tech forum too, but I figured I would get a response here.
Quick question:
I have access to an entire ka24 setup with the 5spd from and s14. Would I be able to swap the 5spd from that into an s13 following the instructions for an s14? Any help is appreciated!
-Dan
94_240sx
Car: 94_240SX
I just did mine a couple of days ago(s14 manual transmission into s13), and yes, it works. I'll give you a couple of tips.
- Block off the hole for crank angle sensor on the transmission. It's on top. I just left the sensor there.- Remove dust cover in the back. s13 driveshaft won't fit without removing it.- You MUST use s13 speed sensor. Remove s14 speed sensor from the transmission and swap it with s13 one.
That's about it. Good luck!!
94_240sx
Car: 94_240SX
Read your post again and are you trying to swap just the transmission or engine+transmission? engine+transmission swap is whole another stroy BTW. I thought you just want the transmission.
djb5118
no i do just want the transmission
94_240sx
Car: 94_240SX
djb5118 wrote:no i do just want the transmission
Oh, cool. Just go ahead then. It works for sure.
djb5118
wait, what if i needed to do the engine + transmission
94_240sx
Car: 94_240SX
djb5118 wrote:wait, what if i needed to do the engine + transmission
As far as I know, it's not a direct swap. Extra wiring is involved. Sorry, don't know the details.
