transmission Stuck
silviasmasher
I'M SWAPPING MY CLUTCH AND FLYWHEEL BUT I CAN'T PULL MY transmission OFF OF MY ENGINE. THERE ARE NO BOLTS HOLDING IT BUT I CANT PULL IT
Nathan
If you cant get it off...then you must have missed a bolt, or just aren't pulling hard enough. You got the starter bolts right? Also...lift up a bit while your pulling it out, otherwise it's binding on the input shaft and crank.
silviasmasher
THERE ARE NO MORE BOLTS. I TRIED PUTTING EVERYTHING BACK TOGETHER AND DRIVING THE CAR, BUT NOW THE CAR JUST JERKS FORWARD WHEN I TRY TO START IT IN GEAR IT WILL NOT START UNLESS IT IS OUT OF GEAR.
NISTECH
did your remove the bolts from the front? including the one above the starter? you probably have knocked something out of line and the clutch isnt fully disengaging from the flywheel when the pedal is pushedThat might be why its jerking.
