transmission strengthen for KA-T????
dppflyinhawaiian
i am going to be doing a KA24de-T soon, and am just had a question. i am going to rebuild the engine and transmission before i put on the turbo kit. i am going to be shooting for about 400-450 hp. but i am only going to push it to about 350hp. i am wondering do i need to do anything to the KA transmission for it to be able to hold that much power? or does it just depend on the clutch and flywheel?
thank you
480sx
Car: 1996 Pearl White 240sx
Its not so much the HP that your making, its all about the torque your putting on the ground. For instance, your Ka transmission can hold 600 hp with street tires because all your doing is spinning. However, put a set of slicks on that same 600 hp Ka and its going to fail.
450 is on the high side of the trannys ability to handle the stress. However, many people have pushed that and much more with the Ka's transmission and been ok. Its a pretty well built package, the 240.
Just boost it till it breaks, your goals are well within reason for a stock drivetrain.
number80
Car: 98 240sx Shell
Actually people with over 400hp almost never are on their original transmission if they actually push the car. There's really not much you can do to the transmission that will be cheap. Another route is to do the Mazwork 300zx swap kit. That kit with the 300zx transmission will probably totalled $1800 though....somewhere in that price range.
480sx
Cory, among a few other .Org members run stock trannys and push 500 hp.
lrb_2000
Car: '91 Nissan KA-T hatch
yeah.. I wouldn't worry about 400hp doing much to your transmission. You should be fine.. I run 350whp daily and it's just fine. Wait until something actually breaks before you change it out.
nelson8708
Car: 1989 Nissan 240sx Fastback
1994 Acura Integra LS
there was a thread on the ORG about having your transmission gears cryo frozen. It doesnt seem to be too expensive to have done. I got quoted a little over 100$ to have all the internals cryo frozen. Along with a few new syncro's and you have a rebuilt transmission that is cheaper than the 300zx options.
dppflyinhawaiian
so from what you guys are telling me is that the transmission will be able to hold up no problem for the power that i want to it at? it will be driven on the weekend, and pushed for drifting on streets/track. so it should be able to hold up?
what is this cryo frozen technique? what will that do? purpose wise?
are there any clutches or flywheels you can recommend for the power i want? im thinking an exedy clutch with a fidenza flywheel, but i dont know if i need a particular stage of clutch or flywheel. any suggestions?
thank you
martins_240sx
Car: 1990 240sx hatch, 1975 280z, 2005 F150 fx4
d21 flywheel(nissan hardbody)1983 300zx/280zx clutch kitthrow out bearing for what ever transmission you have.around $250holds lots of power. held mine without slipping on 2, 436hp dyno passes torque was around that also. still running with no problems.stock transmission
dppflyinhawaiian
so the ka24de transmission will hold just fine with no problems. and itll be even better since im rebuilding it.
question what do you mean by throw out bearing? what is that? is it necessary for the power that i want?
thank you
Ekinchheng
Car: '93 Nissan 240SX Coupe
dppflyinhawaiian wrote:so the ka24de transmission will hold just fine with no problems. and itll be even better since im rebuilding it.
thank you
If you rebuilding your transmission and doesn't know what a throw out bearing is you mind as well STOP NOW and send your transmission to get it professionally done which range 1-2k.
dppflyinhawaiian
im not rebuilding it myself. im having a shop do it for me. i dont have the time to rebuild it myself. my guess is that it will cost around 1,200.
