I have a 94 240sx convertible automatic with 143,500 miles. I've had problems shifting from first to second, but it seems to correct itself and only happens occasionally. Otherwise, everything seemed to be in good order. Today, I noticed that while the car had been driving fine seconds before, all of a sudden, it wouldn't shift. I thought it was the usual problem, but it wasn't. When the light turned green at the intersection, the car wouldn't move - i actually started rolling backwards! It was in drive but wouldn't go anywhere. I turned it off and restarted it, (sometimes that works for various problems, oddly enough) and it moved enough for me to get to the closest parking lot. Very quickly, I was stuck again. No creeping forward in drive or backwards in reverse. I was perplexed. I started and stopped it enough time to get home. I don't quite understand how turning the car off and on would make a difference, even for a short amount of time, but it worked. I checked the fluid level and it seems to be fine - the color is ok too. I would say it's the transmission, but i thought there'd only be trouble with a certain gear and not all of them. Please, someone, help me figure this out! Please tell me it's something small and inexpensive to repair.
