Ceptos »
https://forums.nicoclub.com/ceptos-u840.html
Sun Jun 22, 2003 1:02 pm
i cant really say what your problem is, but a transmission that slips will take extra time to get into gear, its the clutches inside of the transmission that go bad. you will be able to tell, the engine will stay at higher rpm's as it tries to shift. it might also have a hard time chosing a gear at lower speeds when you are applying even throttle, sort of slipping in and out of two. and sometimes at low speed, or when the transmission is cold, it will pop hard into gear when just pulling out, or shifting into drive from park.
reverse is usually the first gear to go out in an auto transmission, one left me pushing my car out of a parking spot after class one night.
