transmission slipping after clutch replacement.
danzan240
Car: 1989 nissan 240sx
sorry i dont know if this goes here, i replaced the clutch assembly on my 89 240 because it was slipping. replaced the clutch, pressure plate, and bearing. the problem is that its still slipping but its hardly moving at all now. it'll go for a bit but once it warms up it goes nowhere, the other night the fastest i could get it was up to 25mph then it gradually slowed to 2mph. we lost prolly about 2 quarts of fluid when we were replacing the clutch. i replaced the fluid but now im stumped... anybody ever had this happen to them? or anybody know what the problem could be? any help is greatly appreciated.
danzan
goldfish
Car: 2005 Dodge Neon SRT-4, 1995 240sx
It's probably your slave cylinder, check it and the master. How many miles on them? You might just need to bleed it though, might be air in the lines
zerothread?id=364662This post might be helpful? ^
danzan240
idk how many miles on the transmission, my odometer reads about 167k but i know its more. my odometer works slow or something. but ill check those out when i can get around to it and let ya know. thanks for the link
carkook
Did you resurface the flywheel? If your slace cylinder or clutch master go it shouldn't cause a slipping affect, but as if you could never disengange the clutch.
swartztech
Car: 1995 Nissan 240sx w/ S14 SR20DET
you align it correctly?
danzan240
i didnt resurface the fly wheel. didnt know about that. as for the alignment we used the little alignment piece that came with the clutch when we put it in. oh and also after we replaced the clutch i could turn the car on put it in first and step outside the car and it would just keep running. it didnt stall like a standard should.
Modified by danzan240 at 11:34 AM 3/8/2009
carkook
Pull the transmission off, your gona have to do it again. It sounds like the pressure plate isnt even pushing the clutch disc against the flywheel.
scottydog
Car: 1992 240sx
Did you adjust the clutch pedal as described in the fsm? try that before you pull the transmission again.
danzan240
anybody have a link to adjusting the pedal fsm style? i tried to do a quickie search. unfortunately i dont have intronet so i just use it when i can. ill search some more next time i can steal a few min if i cant find anything. thanks.
