transmission slip
qx4hart
Car: 2001 QX4
i've noticed a few times with in the past few months or so that my trans hasn't been shifting into O/D. Sometimes at speeds of 55-65 it runs in 3rd or 4th!! It hasn't been doing this alot, i've only noticed this happening a few times. I own an 01 Q and i don't know much about the trans, but I thought that checking out the fluid would be a good start.....pulled the dipstick out, fluid looks clean and doesn't smell like it's burning or bad. Has anyone had problems with their trans slipping? could this be a TPS problem?
pathfinder_se_black
Car: 2000 pathfinder, FG2 civic si
i had similar but thats only when it was cold. after a few stop lights it turns back to normal. im thinking about doing a transmition flush.
SnowSurfLax
Car: 1999.5 Infiniti QX4
2006 Infiniti M35 Sport
Do a transmission flush.
I had major slippage after I ran my transmission to hard through the grapevine (nasty hot uphill pass in CA) and had to get a new pan seal. About 6 months later I must have knocked some gunk loose and I couldn't keep the thing in any gear higher than 2nd for more than a few seconds.
My shop tossed some additive into it and it cleared right up. I got it flushed again a month later and haven't had any problems since.
Mayito
Car: 2001 Pathfinder
My 01 Pathfinder with 85K did the same thing last WI winter and did not have a problem in the warmer months. Evidence of a broken rear seal in transmission which I will have to get fixed.
