ugaexploder wrote:this is pretty funny, after i posted a reply to you i went on to edmunds.com just to see if they came out with any new reviews for the g35 sedan and it actually mentions in the article that it does shift hard in third gear. so yea it's normal.
good question, personally, i'd say it's normal just because edmunds said so lol. but i rarely ever use manumatic mode and if i do it's only through second gear so i can honestly say i've never experienced this but i'll try it out on the highway later tonight when it's not raining. but i'm not sure if it was designed to be like that or not.W661335PF wrote:Is
It it normal b/c Edmunds says so... is it normal b/c it's commonly seen... or is it normal b/c it's supposed to shift this way by design? If the answer to question is that it was designed to be this way, then this normal. If it's normal b/c it occurs frequently or b/c it was identified as an issue, then the issue may be more of a problem than we suspect. Can you find out the difference?
