sil80drifter »
https://forums.nicoclub.com/sil80drifter-u622.html
Mon Apr 28, 2003 2:01 pm
The FSM says that there is also a neutral switch sensor on the transmission, which is right next to the 4th-5th gear sensors, which would flow current when transmission is in neutral, and not flow when otherwise. I've tested that switch on 3 trannies including the one on my s13 right now (all 5sp manuals), and it seems that (generalization coming up) the US models do not have the switch connected/working. It's in the same spot as the FSM describes, and it's the one switch not mentioned by you guys, so it has to be the "neutral sensor." Unfortunately it does nothing. I was going to use it to hook up to my remote starter, which right now is running on the not-so-safe "I always keep it in neutral and the e-brake pulled up when I leave the car" mode. I'll install another sensor for the shifter when I can, but for now... it really sucks that Nissan ripped us off on that neutral switch.
sil80
