transmission sensor question
slidewayzinak
i just got this transmission and i know some stuff is missing just dont know what it is exactly.i drew on the pic to help out. and if its missing anything else that i didnt draw let me know thanks.
Modified by slidewayzinak at 12:46 PM 2/5/2007
slidewayzinak
that first one is the speed sensor. must have had a brain fart
Modified by slidewayzinak at 12:47 PM 2/5/2007
slidewayzinak
this is the line, maybe its an sr thing
180fan
Car: 89 fastback
yeah speed sensor and that's the breather tube.
slidewayzinak
what does the breather tube do
VitaminT
Car: 93 240sx SE
It is just a vent so the case isn't sealed. It runs to the top of the bellhousing because that is the highest point and will always be above fluid level. It normally attaches to the top right bellhousing bolt.
I can't remember the order of the sensors but the one near the back high on the case with the wires stipped is the neutral position sensor I think.
There is one other that is the reverse sensor to trigger the reverse lights.
I will try to get you the page in a minute that has all the sensors in the transmission and what they are. I know my s13 sr had fewer sensors than the s13 ka.
slidewayzinak
thanks
