transmission removal question
j-z
Car: 95 240sx
how in the hell are you suppose to get the four upper bolts out??
sdtouge
Car: 1990 240sx coupe
if you have power tools get back near the center carier bearing and use a long extension a a universal wobly. you can get them from there.
if you have hand tools try from top or just accpet 20 little cuts.
j-z
Car: 95 240sx
ok, just making sure theres not some magical trick that im not aware of. lol
sdtouge
ya, its a pain in the arse. check your email
Toddles82
Car: Computers, Water Skiing, Cars
loosen the motor mounts and tip the engine back (my dad and I use an engine hoist and pull up on the engine). You can get a socket on it like this.
GnarKiller
sdtouge you have to realize the S13 has soo much more room under their to work with than an s14. what i did is just got my good ol' 14mm wrench and somehow managed to get my hand between the engine and firewall and my hand did not come out until the bolt was out. if you can, use a universal joint in addition to an extension with the 14 to break it loose then work it with the wrench.... By the way you dont have to put them back as long as you have all the others then you should be fine.... Thats how i did it.
Zach
Modified by GnarKiller at 1:18 PM 1/22/2005
D1SR240
Car: 2002 BMW M5
1991 Nissan 240SX
Using a socket was a real pain in the butt, so I just used a regular wrench.
j-z
Car: 95 240sx
i got them out with a u-joint. thanks guys
NX95240
Car: my KA-(sc61)
i did this too about the same way as (Gnarkiller). it was a b**ch for sure. getting it back in REAL fun for me.
