GorillaClub »
https://forums.nicoclub.com/gorillaclub-u11667.html
Wed Mar 29, 2006 8:38 am
OK folks this is what I did.
Buy a KA transmission anywhere good or bad, just make sure the input and output shafts are good but more importantsly the bearing seats on the case itself are not warps bent broken or oversized.... so basically just make sure its decent lower milage on it.
Buy the KA rebuild kit from anywhere... Nissan dealerships have them so do many other sites. Take the rebuild kit, which comes with everything you need except the actual gear sets, and seperate the synchros out of it.
Take the gear set and all synchros and go get them cryo treated, its simple inexpensive and increases the strength by 30% on steel 50% on aluminum.
Now rebuild the KA transmission or have a shop do it, you will have a fresh transmission with 30% more strength. the weak point on all sr and KA rannies is the synchros then the gears so you have eliminates that. Bingo a transmission that will hold more power and guess what you didnt spend 2 grand putting in a 300zx transmission
