Koguchi »
https://forums.nicoclub.com/koguchi-u66986.html
Thu Jun 12, 2008 10:43 am
Well that one went to the bottom of the two grounds on the alternator.
Also though the battery/alternator won't hold a charge. could the ground from the block to the chassis help with that as well? Cause I've had that problem since I bought the car like 4 years ago.
Oh! and this morning when I turned on my car to test it some more, I put it in reverse (Any gear that I put it in at that point was really hard to shove in there) and even with the clutch in, the A.S.C.D. was working and moving the car on it's own. is that normal? I redid the wiring so that it's just the starter and alternator to the relay box and the pos battery cable to the starter. with the negative in the stock position on the intake manifold.
Sorry for all the questions I just wanna drive her
Modified by Koguchi at 3:29 PM 6/12/2008
Modified by Koguchi at 3:31 PM 6/12/2008
