transmission question
fallen180sx
Car: 90 Sil80
will a sohc transmission work on a dohc motor? im not using the sohc clutch or flywheel i just need to use the transmission itself and the wire harness.. just need to know if it will work. thanks
Florida240sx
transmission's are the same.Harness though I can't answer.Trying using search button.
Florida240sx
fallen180sx
Car: 90 Sil80
Florida240sx wrote:zerothread?id=98468
i did search and like the post you showed me, it just talks about search. and it never says how to make the wire harness work.
240sxluv
Car: 1989 Nissan 240sx fastback
the trannys are the same through 89-94 i dont know about the wiring harness through
