transmission pull
eastcoastchaos
Car: 95 240sx
hey, i'm putting in a new clutch and flywheel in a few weeks and i'm not sure exactly what i need. i've got the flywheel, clutch is on the way. is there a gasket. i know i need an allignment tool, throw out bearing, pilot bushing, new fluid. am i missing anything. and will a regular auto store have the tool, bearing, bushing and fluid. thanks
sdtouge
Car: 1990 240sx coupe
your clutch should come with a kit for that, if it doesnt, go to the auto store and get gear oil, throw out bearing, pilot bearing(should come with your lcutch) alignment tool.
there are no gaskets.
i would recomend draining the fluid first, otherwise its messy.
mark the driveshaft were you drop it by scratching it with a razor blade, you might never have to market it again.
have ready wreches and sockets ranging from 10mm-19mm, and a cheater bars helps.
you will need a friend to help you with this (it makes it soooo much easier).
remember to remove all sensors, the slave cylinder, starter before droping the transmission.
you will need a torque wrench for the flywheel.
you need grease.
have a fun time, and its recomended to breakin the clutch with smooth easy driving for about 500 miles before its ready to be beaten...i didnt, but i just found out that you are suppost to.
good luck and have fun.
remeber, you can pick unp the ka transmission alone, but just to place it on/off the jack during the flywheel/clutch stuff.
matt
sdtouge
oh, i forgot about this, when you get to the throw out bearing, there is a wierd clip, i dont know how to do it, i just poked and pulled and twisted it for about 3 hours and finanly got it, i would research that.
matt
eastcoastchaos
Car: 95 240sx
bad ***, thank you . and any idea how much for the tool. ew also for the marking of the driveshaft i'm a little confused. just a mark on both pieces that bolt togeather?
sdtouge
ya, i suggest taking it down at the center carrier bearing, then scratch into it, on both sides with a razor blade. you need to mark it some how (not at the transmission thoguh) because the driveshaft if balanced the way it is on your car right now.
the tool should be like 5 bucks, or see if someone wants to sell a used one to you, just start a thread in the sale categorie...
if you dont have some sort of manual i would highley suggest it, especialy when you putting everything back together and you have like 50 bolts and have no clue what goes where.
let mem know if you have any questions.matt
smokin240
I hate to say it man but its a hell of alot harder than it sounds if you've never replaced a clutch on a 240. Maybe its just me and my friends and I just had bad luck, but getting the transmission on was a nightmare and anyone else that has done it on a 240 knows it to be true. If your going to do this don't forget the slide hammer, you can rent it from autozone for free for a deposite of $40, also don't forget the attachment to pull the pilot bushing out and replace that. I also used it to take the throw out bearing too. Like he said, try to keep good track of what bolts go where, if not, your going to have a real hard time figuring out what bolts go where. Good luck!
koukiKA240
Car: 1991 240sx KA-T
It is no small task, but it can be done.
I dont know why sdtouge said you need a slide hammer? Ive pulled the transmission outa my car twice in a driveway and 2 other times i had it on a lift. Its only a little bit easier with a lift for the particular thing. Even if the splines are ligned up and it is part of the way in, chances are its not gonna just slide the rest of the way. How to get it all the way on will take some creative thinking.
But dont let the difficulties discrouage you, once you do it the first time the rest will be easier and easier.~Sam
smokin240
slide hammer for pulling out the pilot bushing.
sdtouge
i nver said anything aout a slide hammer
eastcoastchaos
Car: 95 240sx
well it's a pain in the *** but it's finally done. BUT i cant drive it cause i effed something up. the clutch wont move now. it's locked up and doesn't do **** any ideas?
180fan
Car: 89 fastback
check how you aligned the bearing and the fork.
eastcoastchaos
Car: 95 240sx
well i bled it and got it to move now but the slave cylender deeley is still all sorts of screwed. no pressure in clutch and now the little shaft on the slave cylender sticks out too far to get it back in.
sdtouge
did you end up getting/using the alignment tool?did you reinstall the slave cylinder?
eastcoastchaos
Car: 95 240sx
yes i used the tool, everything went in exactly the way it came out, i even labeled things as they were coming out. and now i'm trying to bleed it. as soon as i tighten everything up though the clutch locks. is my slave cylender maybe just screwed.
