transmission PROBLEM
MAXVETTE
Car: 1995 PATHFINDER
Good morning new to board, I lost reverse in my 1995 pathfinder this weekend auto transmission goes forward but not reverse, you can feel it go in reverse when you put it in R but does not move, good fluid not burning?any opions on this!
Thanks in advanceMaxvette
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Its pretty common with the RE4R03A trans (thats in the pathy, twin turbo Z, Q45, etc)... You are either going to have to live without reverse or replace the trans. You could try doing a flush and cleaning the pan/filter as well.
KoukiS14
Car: 2005 Infiniti G35x
Lakeshore Slate / Stone
elwesso wrote:Its pretty common with the RE4R03A trans (thats in the pathy, twin turbo Z, Q45, etc)... You are either going to have to live without reverse or replace the trans. You could try doing a flush and cleaning the pan/filter as well.
ouch. .
Welcome to NICO Max
nissandoms47
Car: 2002 Nissan Pathfinder SEV6-Custom 7" lift-33-1250R15 BFG KM2- a bunch of other s*** i cant think of
Wrong, the pathfinders came with the RE4R01A transmissions. Probably burnt out the reverse clutch.
KoukiS14
nissandoms47 wrote:Wrong, the pathfinders came with the RE4R01A transmissions. Probably burnt out the reverse clutch.
http://en.wikipedia.org/wiki/J...ssion
elwesso
2007 BMW M Coupe
yeah you're right, my bad, they are basically the same transmission though (except the 01A is less beefy).... I know something else besides the Q45 and twin turbo Z used the 03A..
The wikipedia article is wrong though because the Q45 definitely uses the RE4R03a, but you guys dont care about that..
KoukiS14
:o I care about it!!1It's interesting to me, and maybe it's wrong, but the auto in my QX is the same as a 240sx. .
elwesso
2007 BMW M Coupe
the 240 definitely does use the 01A...
KoukiS14
I think I speak for everyone when I say that at least you didn't have this type of transmission problem:
KoukiS14
elwesso wrote:the 240 definitely does use the 01A...
Seems like a huge amount of overkill for our USDM N/A KA. . hahaunless it's just underkill for the 50,000 pound QX4. .
