transmission problem
clever240sx
Car: Nissan 240sx
DOnt worry i searched on this and i couldnt find anything. But i just installed my rb motorset and i hooked the line up going to the slave cylinder and i bled the line. But my clutch pedal wont work(very loose and wont let me shift). Whats the problem? Let me knowthanks
Joe
you need to adjust your clutch pedal
look under the dash, there is a metal rod that goes into a fork with 2 nuts. loosen the 2 nuts then rotate the rod.
spec is .5 inches of free play on the pedal before you feel any tension. you may have to adjust off of "spec" to get a proper feel.
clever240sx
Car: Nissan 240sx
I dont think that is it. My pedal wont even stay up, it just falls to the floor. Also when i bled the line, there was air bubbles but there is no leaks in the line. Possibly a bad slave cylinder?
Joe
you neglected to tell us that part lol
and did you get all the air out? sounds like air could still be in there.
clever240sx
Car: Nissan 240sx
Woopps my bad, i posted that and i went to a basketball game and i was in a hurry and i thought about that when i was there.. But yea i got all the air out. And then i keep thinkin its all out and then some more bubbles come. I was doin this for about an hour....so i dont know what to do.
Joe
gravity bleed.
open the slave bleeder. open the cap on the clutch master. watch the fluid drip. may take a minute or so for the fluid to come out. but it will come out in a steady stream once its bled.
you dont have to touch the clutch this way and it insures its a good bleed. if your problems are STILL there check pedal adjustment, and it that still dosent fix it looks like its time to replace the master and slave.
clever240sx
Car: Nissan 240sx
Ok i did that. I got a good steady bleed. Pedal still wont work. SO i changed the slave cylinder but i swapped it out with a ka slave cylinder. It was just a little bit bigger but it fit real snug. But i tried it again, eccept now it only drips and no stream. I dont know what is wrong. I dont know if this matters, but i havent done any of the wiring for the transmission yet..i dont think that should matter, but who knows.LMK!
