transmission problem
jin3001
Car: 95 &97 240sx
97 240sx w/sr and auto to manual swap.finally got the car running,checked all fluids and started off driving,noticed a slight slipping in third drove a little more slipping worse now in second waited at a light ,could barely get moving again.got back to the house and checked all fluids again, clutch master cylinder, all tuber and hoses leading to the transmission this took about 30 -45 min.all good.started car up it moves again but when i start driving it starts to slip again as if the hotter it get the more it slips .could the clutch be going out?
nightkid86
Car: 97 S14 SE
Sounds like the clutch is going out. Also, perhaps the clutch fork isn't installed correctly.
irocknrol2
Car: 1991 240sx Hatch/1993 240sx Coupe
If the clutch is slipping (engine revs, but not much forward movement), then you probably have a worn disk. How many miles on the clutch disk? I doublt it would be a problem with alignment of the clutch or clutch fork. That would show up as a grind or clunk or chatter noise.
blacknissan92
Car: 92 nissan 240sx turbocharged
maybe it not adjusted or bleed corectly
