4cefed »
https://forums.nicoclub.com/4cefed-u1486.html
Fri Jul 23, 2004 1:27 pm
Well, I've never had one of these apart before, but in other transmissions the shift fork has a couple plastic pads on it. If you drive with your hand on the shifter, it wears the pads on one side. So, it goes in fine from say 1st to 2nd, but grinds from 3rd to 2nd. SOmeone that has had one apart might be able to say if these are the same design.
