transmission problem help! anyone
musk'r
Car: 92 240sx coupe
cant shift into 5th gear and sometimes i cant shift out off reverse.whats the problem?is it syncro/sync how do i fix that..
Joe
double check your shifter installation and alignment inside the transmission
if its still not working, you probably have a bent/damaged rod in the transmission
easiest fix? replacement with another used one.
musk'r
Car: 92 240sx coupe
alright thnx
Patarach
Car: 240sx convertible KA-T
If you do end up removing your transmission pop open the front cover, (should be like 5 bolts) there will be three holes in the bellhousing that are used like bushings to keep shifting rods in place, all these rods should be in the even with eachother (as far as protrusion) . If not that can cause problems similar to what you described.
other than that your best move would be a new transmission, typically $150 of cl, just make sure it goes into every gear, and spins in every gear and it makes no obnoxious bearing rubbing noises when you turn it.
musk'r
Car: 92 240sx coupe
thnx...yea i think im going with a new(used)trans...haha
