transmission problem found...............
afmafia
ok guys last week i couldnt get my car, so last night the transmission came down and the clutch was melt on flywheel in one piece we had to use a pry bar to get it off. what the hell could of done this. This is what i dont get friday we took down transmission cause my output shaft was bad. so he installed the clutch thAT HAD ABOUT 600 MILES ON IT ON TO THE NEW transmission. we inspected the clutch and it looked great , the next day the car wouldnt go in gear. any info is appreshated thanks jon
Nismo_Freak
Car: 89 Nissan 240SX
Something in the hydraulics is bad.
afmafia
u mean somthing from between the clutchmaster cyl and the slave cyl
Nismo_Freak
Yes, either one is bad causing the clutch to slip while you drive.
