Chew40sx »
https://forums.nicoclub.com/chew40sx-u19946.html
Mon Sep 20, 2004 10:55 am
OKay,
I bought a KA24DE (motor + transmission) off this guy who did an SR swap with his 91 240. He said that there was about 180,000 km's on the engine. So this weekend I went ahead with the swap and everything went fine until we tried to tighten the crank pulley. It was turning even when the car was in 5th. Also, I can only have the car in the neutral position and go over to the right and into 4th and 5th. No 1st, 2nd, 3rd or 4th and it won't even go to the left, just center and 4th and 5th. We've hit a dead end and are hoping that it's not a broken shaft in the transmission. The shifter is a B&M and I took out the stick only to put transmission fluid in. It's a bit of a ***** to get back in but it eventually fit in. I also replaced the clutch. What I'm thinking now is that it could possibly be the clutch slave or maybe the throwout bearing isn't working properly. Not too sure. Can someone help? I miss my baby!
