Postby
aircadet759 »
https://forums.nicoclub.com/aircadet759-u148778.htmlTue Dec 01, 2009 8:45 am
k soo i have a skyline GTR
this is the problem....i start the car, stick it in gear and let the clutch out; but nothing happens...its like the car is still in neutral. This happenes in every gear...im thinking i need a new clutch assembly but not sure?
Postby
Count Zero »
https://forums.nicoclub.com/count-zero-u51087.htmlTue Dec 01, 2009 12:28 pm
That's what mine is doing, only it's been a gradual thing that gets worse every time I drive....as in, it's obviously the clutch wearing out.
If you want to be sure, drop the trans out and pull the clutch off and have a look at it.This is also how you'd check the trans shaft, so that's the best place to start.
