tumolt »
https://forums.nicoclub.com/tumolt-u30985.html
Tue Aug 15, 2006 2:42 am
ECU unit may have burned out. It is located under the passenger side kick panel, at the top front behind the blower motor. A bit of a pain to get to. When you finally get it out you would have removed the CPU for the engine, unfastened the PDL module?, and removed the blower motor to access it. It plus into a harness just like the CPU. When you remove it there are three cover screw which you remove with a phillips head screw driver. Look at the resisters (Grey with stripes) and look for burnt ones. You may want to take it to someone who knows electronic components to do a visual with you. An ECU rebuilt is in the neighborhood of $175. with your old one exchanged. Forget dealerships, they want $500. Also you should have your transmission pressures checked. There could be other problems that need attention. Good luck. Matt
