If you tried starting the car while in first and the car moved, that would mean that your clutch isnt disengaging. Does your clutch pedal come back up after you let go of it? If it stays on the floor after you press it you definitely have lots of air in there still. You may have a bad slave cylinder but unless you see any leaking fluid Id think that you just have air in there. Try pumping the clutch multiple times, even if there is an absurd amount of air in the line, this should slowly build pressure in the system and disengage the clutch, if it doesnt, you may have a bad master cylinder or slave cylindersr20-thoj wrote:I finally got my car started, but for some reason i cant get it to go into gear at all. I bled the clutch twice already. not sure if im doing it right or wrong. I tried starting the car while its in 1st gear, but it wants to move. any ideas??
hmmm...it just occurred to me you may not have a bleeder on yours. I got two master cylinders when I did my swap and I used the one that fit better and it had a bleeder on the side of it and the line was underneath... the other one had the line on the side and there was a screw underneath. I suspect that's where you bleed it from.sr20-thoj wrote:How do you bleed the master cylinder? how do you take off the damper box also?
Sounds like you may have a leak in your lines somewhere if sometimes it's harder and other times not....if there's a lot of freeplay though try adjusting the master cylinder arm at the pedal and lengthen it.TougeTune180 wrote:I am having a similar problem, like it shifts ok, but its really hjard to shift, the pedal has tons of free play, and it wont engage/disengage harshly at all (i.e. sidestep it from 4000 rpm and the revs just drop and it bogs). i have also bled mine like a thousand times and it doesnt seem to help. sometimes the pedal will be real soft and squishy and then other times it will be the correct hardness. I am using an Exedy Organic Copper Mix Stage 1 clutch and pressure plate. any help is appreciated
