transmission parts and clutch surprise
cdorhout
Car: RB30DET with VCT -- SOLD!!!!
Next project TBD
I'm tearing the motor down to build internals this winter and I was surprised to find a Nismo Gmax (Exedy) dual plate clutch inside. When we installed the motor we never even disconnected the transmission from the motor so i just found it now.
Also, my motorset never had the transmission bracket for the drivers side. Does anybody have one of these laying around unused? This picture is the for the right side, but I'm missing the left side one. I need the bolts for it as well
Shocker
Car: 89 240sxHB rb26/30
shiitt no wonder the stock clutch was so heavy.... never even opened it!? lol. Nice find for sure.
silviasgp06
Car: 95 Nissan Zenki RB25 Powered
that is what you call "Lucky"
BoostFab
Car: S13cp, S13fb, S14z
lucky bastard
240z4u
Car: '95 Nissan 240SX
Wow, kickass find. Thats exciting.
I need to see if my drivers side bracket will fit after I moved the motor up. If it still does not fit you can have it.
Evan
cdorhout
Next project TBD
Well, it's kind of a blessing and a curse. So far, I haven't been able to find replacement clutch disks for it, and if I do I'm sure they'll be $800+
Can anybody help in finding a rebuild kit for it?
The part number is RS055 and it's made my Exedy just branded Nismo Gmax.
Nobody has any extra transmission brackets laying around from a blown transmission?
bauchrb
Car: s13 w/ RB25 Gt4094r 640cc inj. AEM EMS
no idea where to get the replacement parts, but its the same clutch I've got. I picked mine up off a guy in orlando when I lived down there. Mine only has 1000mi on it maybe??? But would love to get discs and what not to rebuild it later, if you find a place that's got 'em.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
RHDjapan should be able to get your the replacement parts for that clutch.
As for the braket, I should have one in the garage, I'll double check.
cdorhout
Next project TBD
I checked RHDJapan and couldn't find the replacement clutches. I'll keep looking around though.
That would be great if you could find a bracket in your garage, I'd be happy to buy it from you.
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
Blessing + Curse. But sweet find, regardless!
HxC_Nismo
Car: '98 Nissan 240SX SE R33 RB26DET
'07 Nissan Titan SE
'05 Toyota Corolla
yea i have both rb25 transmission brackets since i used the rb26 oil pan on my swap so i didnt need em. i think you still have my phone number just give me a call and make me an offer if you dont have my number ill just email me at [email protected]
cdorhout
Next project TBD
sweet! Yeah, i still have your number. I'll give you a call soon. thanks!
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
no problem man
Carl H
the full clutch kit is the following number:3002a-rs591it is the spec 2 nismo gmax clutch capable of 870ps i think, i cant read japanese...
here are the replacement part numbers:clutch cover 3021a-rs055center plate 30125-rs020friction disc 3010c-rs045cover to mid plate bolts 30131-rs020clutch cover to flywheel bolts 30132-rs020flywheel 1231c-rs590
thats from the nismo catalog i have, the pn's may have changed.
cdorhout
Next project TBD
Wow, thanks Carl!
With those part numbers I was able to find the disks on RHD.
$273.33 for each disk. That's cheaper than I was expecting.
bauchrb
very nice! Thanks again, Carl to the rescue!
gawdzilla
Car: none
might be a gamble, but if you contacted Exedy and got the replacement discs for their Twin plate for rb25, it might be a little cheaper. I'd imagine it being the same disc without the nismo markup
Coolwhip
Vendor
if i'm not mistaken I believe that the Nismo clutches are totally different that require them to be installed on some sort of gear looking hub instead of having the input shaft actually sliding through the splines of the clutch disks themself.
cdorhout
Next project TBD
I have the clutch off now, and it appears to be a normal type clutch disk. Nothing special about it.I have an OS Giken dual plate clutch on the shelf too, and this Nismo one assembles completely different, but the clutch disks look the same.
Yeah, i may try to cross reference the part number to an Exedy number and see if I can pick them up any cheaper.
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
if you need those trannie braces give me call or email me [email protected]
imported_z32 tt
Hey searching for a while now and thankfully carl knows what his talking about. I have the same clutch for nissan 300zx and just want to know what parts (along with the disc's) to replace to get it back to good condition??? do i need to replace the clutch cover?
Coolwhip
Vendor
usually the clutch cover is fine unless you have some sort of scoring or heat marks on the surface. Also test the tooth tension on the pressure plate.
Besides that you'll need the disks, and the intermediate plate if there is one.
