That's what 95% of the dealers do. Neither they nor Nissan has an interest in keeping your transmission working past the end of their warranty. They are in the business of selling parts and installing them, not prolonging the life of any car past warranty expiration unless the owner specifies and pays for specific procedures.NightRiderQ45 wrote: Maxnix, to my surprise, I did notice in the FSM where it stated to do multiple drain & refills if the fluid isn't clean. I mean we all know that it won't be clean with only 1 drain/refill, but I was surprised that the FSM stated to do that, especially since you are so against that.
Exactly! Bingo! When I first joined this site, I jumped on the M1 bandwagon because I didn't seach much. After searching, I realized that basically, I didn't need to spend the extra money. My next fluid change will be with Dex-VI. I mean, I did put 175k on using "dino" transmission fluid not M1.elwesso wrote:I really dont think theres any use in using synthetic oil in the transmission if you just change it every year and be done with it...
By the way, Wes does mean mechanical exchange, not just drain and refill.elwesso wrote:I really dont think theres any use in using synthetic oil in the transmission if you just change it every year and be done with it...
I understand the reasoning using syn fluids, especially oil. Now syn oil is far more valuable than syn aft though. I know that installing the aux transmission cooler will bring down the temp., but there was a post actually multiple posts where people stated that using M1 alone will drop the transmission temp 10deg. That's what i didn't believe. Yes send me pics, I would like to see them.maxnix wrote:By the way, Wes does mean mechanical exchange, not just drain and refill.
The advantage to the higher grade synthetics, once again, is resistance to break down at elevated temperatures. A concern in mountains, steep hills, high speeds, and hot summers.
An auxiliary stacked plate cooler will bring down ATF temperatures more than 10° F. Read Skibane's excellent post on hose routing with one installed on a FGY33.
I have used conventional (very little oil, if any, came from dinosaur decomposition) in my Acura Legend for over 183K. But I can send you pictures of my VH45DE valve covers and heads with M1 since 55K now at 102K. Pretty much appear as new, and better than any other I have seen published here. M1 doesn't varnish like conventional oils.
