i stand corrected!p00t wrote:240kid: if the clutch is up and you hear a whirring sound then it is the input bearing. as the bearing wears it will get noisier, but that does not mean it will fail.
pilot bushing and throwout bushing are only stressed when the clutch pedal is to the floor. The pilot bushing has the job of keeping the end of the input shaft secure and steady at all times. If the clutch pedal is not being pressed then the input shaft and crank are turning at the same speed, so it could not cause noise then.
So why is it the input bearing? because when the clutch is pressed all the way in that is the only time the input shaft can stop spinning.
but if the throwout bearing and input bearing are both bad? time for a vg30dett swap.
