transmission oil change instruction?
Ren
Car: 1995 240sx
um.. I've done some search, results were what kinda brand and what grade to use.
is there a instruction that any1 can provide for the DIY transmission oil and diff.oil change?
Thanks
sdtouge
Car: 1990 240sx coupe
drain the fluid at the bottom of the transmission, and then there is a sqaure bolt on the drivers side of the transmission were you refill. put fluid in until it overflows.
Ren
Car: 1995 240sx
exactly locations? pix would be great.thanks
navysnail
there was a diy on this a while ago, i think fiznat did one, leme check real quick.....
navysnail
Ren
Car: 1995 240sx
thanks alot
xung
If you don't have some sort of pump, the easiest way to get oil into the diff is by using some vynyl tubing and having someone hold the other end 4~5 ft high. Make sure the car is level when filling so you know when to stop.
