transmission NOT SHIFTING INTO OD
DLYNNW
Car: 89 nissan S13.5 97 Kouki s14 06 toyota Bb
i bought a 89 240sx hb off a guy and he was messing with the gauge lights that were not working and touched something now the cars not going into OD plz he pplthanx dustin
(Q)240
Car: 92 240sx s13 Coupe
OD??
98s14inaz
Car: 2010 Nissan Titan Quad Cab
Overdrive
Kataki_
Car: daily 95 s14 autotragic project 92 nissan 240SX fastback rip93 fastback 1st car
So clarify the question. I can't fully understand it
DLYNNW
my trans is not going into overdrive the rev fuse was blown i changed it and it shifts into OD now, but the speedomiter is not working
98s14inaz
Pull auto transmission and replace with manual transmission FTW
RCG_Savage
Car: '92 240sx fastback
Vehicle speed sensor probably went bad or you accidentally bumped/disconnected it some how.
DLYNNW
were is the speed sensor located at
thanx
im planing to rb swap it this sping but i need to drive it till then so it will be man. then. thanks
98s14inaz
Last sensor at the rear of the transmission. Seeing how yours is an auto it should have a pink gear. You need to replace with another auto speed sensor.
